Onkyo mini system at Circuit City
Would this system http://www.circuitcity.com/ssm/Onkyo-Shelf-System-MC35TECH/sem/rpsm/context/9900 1308/oid/64934/rpem/ccd/productDetail.do
be able to hook up a turntable to it? One with a pre amp built in?
Thanks
Username: Edison
Glendale, CA US
Post Number: 620
Yes - if it has input RCA for a tape, you can use that. If no other input than a CD input, then you might have to unplug the CD and plug turntable RCA to CD input.
I am pretty sure it has other inputs, so you are ok.
By the way, it sounds pretty good - one of the best sounding mini systems I heard.
