What Home Surround Speaker Should I Use With My Denon 3805?
Username: Chainsaw
Just Purchased the Denon 3805 and would like to know what would be the best (Home Surround Sound Speakers) I should purchase with this Receiver. My Gathering Room is about 24X22 and would like to stick with some satellite speakers if possible. Looked at the Bose $1299.00 (AM15IIBLK) but didn't like the Bass or the setup. Having to connect my speakers to the sub-woofer didn't make me happy.
Thanks for all opinions
Chainsaw
Yep, Bose speakers work best if you use their amps. IE a lifestyle system. Can you use in-wall speakers or are satellites definitely the way you want to go? In most cases they go through the sub because it essentially is the 2nd half of the speaker. If in walls are an option I can suggest a few great choices. What is your speaker budget?
Username: Chainsaw
I selected the POLK RM7200. and so far they kick butt... but I don't really know what I should be listen for. I got a good deal on them for $899 from CCity. Thanks for your input...even though I made a decision
