General question about buying an amp
Username: James_the_god
Doncaster, South Yorkshire England
Post Number: 92
I was just searching around sites that sell amps and comparing all the wiring that i may need. What the sites don't say though is if the amps come with a power supply.
So, when you buy an amplifier does it included a mains plug? or does it just run of other sources. Stupid noob question i know.
Thanks
Username: Tevo
Chicago, IL USA
Post Number: 146
Most if not all components will come with mains cable. Most mid-fi and some entry level fi have captive mains (the cable is not-detachable from the component).
What you will need to supply is interconnect cable (to connect your source).
And speaker cable (to connect your speakers).
