Like
New ARCAM ?
Daniel Benatar
Hi all,
As you probably know, I am owning the NAD T773 but not happy... so to say... And today I went to a local dealer and asked him about ARCAM, and he told me that new system is due within 1-2 months? Any one know about it? Should I wait, I still have my T773...
I have logged into the ARCAM web site and did not find any thing on future systems.
Any further info will help.
Thanks, Daniel
Username: Frank_abela
Berkshire UK
Post Number: 416
There is a new processor/power amp combination just coming out. It's in the Diva range and is just over half the price of the FMJ processor/poweramp combination. It's not in the same price bracket as the 773 therefore. If you're looking to upgrade the system, it would be worth waiting for a listen. Otherwise you're looking at the AVR250 or AVR300. I heard the new combination demoed at a hifi show where it was being launched just two weeks ago and it seemed very good...
Regards,
Frank.
Username: Dary
Sao Paulo Brazil
Post Number: 60
I recently came to know about B&K receivers (AVR-507 S2). I've found good reviews on them. Unfortunately I can't listen to this unit. Are they comparable to Arcam, NAD and Rotel?
Thanks, Dary
Username: Markusp
Toronto, ON Canada
Post Number: 103
Daniel - as I understand it, the new Diva pre pro is the processing section from the AVR300 but with some new / updated digital connections. I believe it has the same DACS, processor and circuitry as the ARV300 but will have a beefier power supply and heavier chasis. The amp itself is a more refined version as found in the AVR300.
If you don't mind the units beeing combined into 1 unit, I say go for the AVR300 as it will save you money and still probably give you 90 - 95% of the overall performance.
I have no inside info from Arcam, this is just my understanding of all I have read re: the new units. Check out www.avforums.com for more info - they have a dedicated Arcam forum.
Berkshire UK
Post Number: 423
Markus
Interesting - while I was at the show, I was led to believe by an Arcam representative that the new Diva pre/power is actually a diluted form of the FMJ combo. Knowing Arcam I'd be surprised if the performance was as close as you suggest. They're very careful about product placement.
Regards,
Frank.
Facebook
Shop Related Deals
Directory
