Directly from KEF
i have emailed the Kef directly asking their support on amp for the kefq1, their suggestion was the Yamaha and nad. is that ok. using it for HT and music thankyou
Username: Two_cents
I have a NAD T743 receiver matched with KEF KHT1005 sat/sub system. The KHT1005 sats use the same Q speaker design as the Q1, but obviously at a smaller scale. From what I've heard so far they match superbly for HT. The sound is very detailed and clear and the soundstage is convincing. I bought my system mainly for HT; I have a separate system for audio. But I would think the NAD/Q1 combo would work well with music. Any NAD AV receiver will have enough good, clean power to drive KEF Q speakers.
thanks for your answer, is the qseries to NAD 763 a good combo or recomend some other speakers to match. like it for HT and music. also how is the marantz and q1 combo.
Username: John_a
Post Number: 232
See also the thread KEF speakers
Randy McIntyre
I've been using a NAD 320BEE with Q5s for a while now and they sound great. I tried using a HK but didnt like the combination anywhere as much.
