Ohms and Frequency Response Range
Username: Dhearn
Houston, Tx Usa
I want to do whole house audio. If the speakers that I'm thinking of buying are 8-ohms, how many can I install on one receiver? Also, how important is the frequency response range of speakers? JBL has a pair of 2-way, 8", 120w in-wall spaekers. The freq. response range is 30Hz-20kHz. Am I going wrong by buying these speakers for this type of application? Thanks
J. Vigne
"If the speakers that I'm thinking of buying are 8-ohms, how many can I install on one receiver?"
It depends on how you hook them up.
"how important is the frequency response range of speakers?"
It is not important.
"Am I going wrong by buying these speakers for this type of application?"
Probably not.
