Panasonic SAHE 75
Username: Fitzz
Do most newish receivers have a "cable" input for
radio reception?All I can see is a FM and AM loop
antenna connection.I would like to split my cable
and run into TV and into receiver.
edster922
what you need is a coaxial splitter and/or converter...I'd suggest a trip to the local Radio Shack, preferably with a digital snapshot (esp. if you have a camera cellphone) of the connection on the back of your TV and the back of your receiver. Should all be taken care of for well under $15.
