Technics SL-230 Turntable calibration light bulb
Candy in Oregon
Does anyone know where I could find a replacement bulb for this turntable? It is used as a strobe to calibrate the speed.
Username: Dvautier
Bellevue, Wa Usa
Post Number: 25
measure the voltage. then go to rat shack and ask them for a small neon bolb. it has two little terminals and flashes at 60 cps. that should work. may have to order it.
