2 Digital Coaxial feeds into 1
Username: Hcjfilms
I have a reciever with only 1 digi coaxial input. Is there a way to get more than 1 digi coaxial input into 1?
thanks
Username: Paul_ohstbucks
Post Number: 727
You can buy Y adaptors, but before you do that.........
Does your receiver have any optical inputs? If it does, you can also use those.
Username: Hcjfilms
Thanks for writing Paul.
What kind of Y adapter would I need? Yes my receiver has 2 optical inputs but these are taken up. Also, I can only use digi coax for the DVD player and cable box I need to fit into 1 digi coax input
Post Number: 728
http://www.x10.com/electronics/allcategories/computers/cableswiringracksystems/_ ge_AV22601-92601.html
You may find better quality ones elsewhere, but these will also work just fine.
