Basic CD player Question
Username: Denali
OK, now I've read up online on cd players. Am I correct in saying that there is no remarkable differenc in sound quality between high end and regular cd players? I was thinking of upgrading my 6 year old sony carousel with digital out, to something better. If there is no real difference, why the huge price gap?
Username: Tevo
Chicago, IL USA
Post Number: 72
Personally, I find the source has a significant impact on sonic performance.
I've found mass market digital sources generally are unnaturally sibilant (excessive emphasis on "s" sounds). They are also somewhat lacking in resolution, warmth and dynamics.
This said, one has to have sufficiently transparent and detailed components downstream before the "problems" become fully realized.
Just my 2/100ths USD.
Username: Denali
Thanks for your thoughts. Im running it through an Onkyo 502 Rec., with Tannoy Fusion spkrs. Would I notice an upgrade?
Username: Tevo
Chicago, IL USA
Post Number: 74
I'm afraid I am not familiar with either of those brands.
Perhaps other posters might chime in?
Username: Alexfromholland
Post Number: 34
Hi,
Onkyo receiver with Tannoy spkrs should be fine. You should definitively try a decent CD-player and you'll hear the difference. Try a marantz, or Harman/Kardon, or if you really want it all try a NAD (C542 or C541). The sound you hear is much more sophisticated than you ever could imagine from a normal CD. Before I bought the NAD, I was thinking to upgrade to a SACD or DVD-audio, but that thought was gone as soon as I listened to my 'old' CD's .
Alex
Alex
Username: Denali
OK, thanks. I'm trying to decide between Marantz and Denon which I have narrowed down to. Both are the barebone for each manufacturer. I'm leaning towards Denon, it is 70-80$ less.
