Audio Test Disk??
Does any know of any good audio test or demo disk that you can buy? Something that like DTS or DD.
Username: Paul_ohstbucks
Post Number: 131
What?
........to test your DTS?
Username: Tevo
Chicago, IL USA
Post Number: 53
Most, if not all, high(er)end audio/HT dealers should have some demonstration disks on hand.
If you cannot source them from a local dealer, www.musicdirect.com and www.audioadvisor.com have a fairly comprehensive selection.
Chesky makes a number of demo/test discs. The discs for multichannel (DD/DTS) feature test tones, channel effects, etc... the better to impress yourself (or better yet your friends). :-)
Hope this helps.
Moderator
Username: Admin
Post Number: 240
There is a Testing Disc section on eCoustics:
https://www.ecoustics.com/Home/Resources/Testing_Discs/
Im a dj, so i make my own demo disks.
