IR receiver and Elite 54TX
DV
Anyone use a IR reciever plugged directly into the back of the Elite" IR in" jack? The Pioneer manual sugests a Niles or Xantech unit. Did some research on the net and it looks like you have to use a complex system if ir reciever through a conector block. Im looking for something simple as this is the only component I want to control. I want to avoid the flashers..
Thanks
DV
