Witch to go with? Dipole or Direct speakers
Username: Cory
Post Number: 107
For my set up I dont know either to go with direct or Diople speakers.They will be placed about 2 feet above the listening position. And if you would recommend one or they other why?
One other thing I noticed looking at some of the Diople speakers that there frequencies do not cover the hole bandwidth 20-20K Hz
Thank you for your time
Username: Kano
Post Number: 325
IMO direct speakers for in front (ie centre, left, right) and bi-pole or di-pole for surrounds.
Bi-pole is preferable if you are sitting with a wall closely behind your sitting position. Di-pole is preferable when your sitting position has some space behind it.
Some speakers such as the Polk Fxi3 surrounds i use have a switch for bi-pole or di-pole operation.
Username: Cory
Post Number: 108
Kano or any one else, recomend the bipole or Dipole for surrounds witch are located 5-6 feet from the floor and 6 feet to the listeners ears?
