Paradigm speakers
Username: Sunilb
I have paradigm studio 60 series front speaker and compatible centre and sorround speakers.
I am using yamaha rxv 650 receiver .
I feel i am not able to get maximum output from receiver. The volume starts only when it reaches -40 dB.
If somebody can tell me the reason or some adjustments.
Username: Jamesp
Mansfield , TX USA
Post Number: 97
Sunil,
The RXV650 should be able to give you enough power to reach decent spl levels.
Have you calibrated your system yet? Calibration involves adjusting the levels on all your speakers so they are all at reference level. You can get a radio shack spl meter (analog or digital) and AVIA calibration disc.
Username: Sunilb
Thanks James,
RX V 650 has built in feature of YPAO(Yamaha Parametric Room accoustic) which adjust levels of all speaker.
Whether u r talking about the same or something else.
Pls. advise
