Denon 2805 - can't check measurement results? Help!
Username: Affan
When using the Auto Setup feature with the mic, it seems I can't check the measurement results with "Sp Config Check". When I press ENTER, it just displayed "Sp Config Check" and do nothing! -- no information about each speaker at all! (e.g. Front Left = Large, etc. etc). The same with Delay Time Check and Channel Level Check. Is this normal?
