Home Theater Help Needed
Username: Shan
Athens, Georgia USA
Hello Every One,
I am a new member with zero knowledge in home electronics. I need some help from the members. I want to buy a Home Theater System not the package but separate receiver and separate speakers and sub-woofer. (my first venture into home theater) I have gone through many web sites and got confused by seeing many brands and models but at the end I have selected some requirements for the system and I want you members to help me buying the right system for me. My requirements are as follows.
7.1 Receiver with THX selects; cinema mode etc, etc.
DTS, DTS-ES Discrete/Matrix 6.1, DTS Neo:6, Dolby Digital, Dolby Pro Logic II, Dolby Digital EX, Pro Logic IIx
Minimum 100 Watts x 7 Channels
HDTV-Ready
Powered Zone 2 Capability with Zone 2 (Multisource) Line/Pre Out
Composite To S-Video Conversion, Composite And S-Video To Component up conversion
Pre Outs: Front L/R, Center; Surround L/R; Surround Back L/R; Subwoofer
Maximum Inputs and Outputs
5CH/7CH Input
Net Tune; Ethernet, in short maximum features in my budget.
I also want matching speakers and subwoofer for the same.
I have a medium room size at present but planning to move and I will have a bigger room for the same.
My budget is $ 1800 to 2200.
I have read about VR-8070; TX-NR 901; TX-SR 702B; AVR 5803;
Any help would be greatly appreciated.
shan
