How to glue my speakers?
Username: Cichlid187
Hi,
I have dropped one of my Elac Cinema Sat2 (http://elac.de/en/products/cinema/pro/cinema2sat_si.jpg) speakers and the top and bottom have come off. I would like to glue it back together and I am wondering if there is any specific glue I should or should not use.
Thanks,
Harry
J. Vigne
Take the speaker to a good woodworking store or hardware store, not Home Depot, and ask for their advice. You will need some clamps to do the job effectively.
