Bi-amping with nad c 320bee
Username: Casa7
Post Number: 8
Is it possible to connect 2 nad's in order to double the power?
And how would i do that?
Is it bridge and bi-amping the same?
Username: Danman
QUEBEC CANADA
Post Number: 602
Well, I have two C272's with a C162 in Bridge mode with each amplifier powering one speaker. You could also use a C372 and C272 together as well without having to buy a pre-amp and save some money.
Overall, the answer is yes BUT I needed this power as I have a very large room if you don't need it maybe you should stick to a C372 or C162 and C272.
Is there any particular reason you ask?
Username: Casa7
Post Number: 10
a C372 or C162 and C272 is a lot of money for me.
I just think that adding another c 320bbe to mine, i would have more power to drive my speakers, without spending a lot of money
I can get it quite cheap (around €220)
Username: Danman
QUEBEC CANADA
Post Number: 604
You would not really have more power as they are not bridgable but the sound may be more dynamic I suppose.
My advice is to save or sell to buy the 162 and 272.
Username: Ellison
Post Number: 35
Buy a 352 or a 372 instead...
