Subwoofer Noise Question?
Username: Theshark29
Hi,
Every so often, my subwoofer, makes a "passing gas" noise (aka f*rt). Is that normal or is there a problem?
Thanks!
Username: Usa2k4
Post Number: 44
The Jensen subwoofers models JPS8, JPS10, and JPS12 all have this f arting problem. I know it because several friends of mine bought them due to the dirt cheap prices. Audiovox/Jensen doesn't officially acknowledge the problem but their tech services would "check & fix" it if you send the amp to them. If your is also a Jensen, check www.audiovox.com website for tech service contact info. Without this problem, those subs would have been excellent subs for the money because they sound very good and cost very little.
LOL...Yep, I have the Jensen JPS modea, and yep, bought it because it was cheap and i didn't want to spend a lot of money at this point. Thanks for the information!!
