How do I get sound through my speakers from older TV?
Username: Fitzz
I run DVD,CD,xbox,all through my receiver using
5.1 surround sound.My TV is old so I have to use
a RF modulator.How can I get sound from TV using
my 5.1.
Username: Project6
Post Number: 2531
You don't.
Username: Fitzz
.If I bought a new TV,would sound
be in 5.1 dolby digital from TV?
Username: Project6
Post Number: 2532
No. 5.1 dolby digital comes from your sources and TV gets source from a signal like the cable company, satellite provider, etc. The TV in itself will not give you surround sound.
However, if you get a TV that has audio outputs, you can hook it up to your receiver and in turn, you receiver will put it in surround mode if you have the proper set-up.
