Speaker driver replacement
ineednewdriver
Hi, Can i use 10" subwoofers to replace my 10" speaker drivers? I have a home theatre running 100watts to it, will it work? Thanks!
You would be best served by contacting the speaker manufacturer to get a replacement driver.
J. Vigne
The woofer needs to be matched to the enclosure and the X-over. You may substitute a different woofer if you know the technical specifications for the original driver. Otherwise stick with a factory replacement.
