B&Ws or Snells
Username: Bnthouse
im buying a marantz 7400 rec.
looking at snell xa60s or the B&W 703s
any opinions- my living room has hardwood floors
Username: Edison
Post Number: 230
Both are good speakers - a matter of taste. Try to audition them at home - make sure no re-stocking fee, and go with the one that sounds the best to you.
You might want to put a rug under the speakers, and have nothing in between them, like a big TV, for better sound.
Have you heard onkyo 800 and above? I like their smooth non-fatiguing sound. Rich and pleasantly clear. Won receiver of the year in secrets of HomeTheatre for under 1k. Might want to hear it.
www.ecost.com has good price on ts-xr800 refurb.
Username: Bnthouse
I have an onkyo 601 now- should I upgrade to
the 800?
Username: Elitefan1
Post Number: 87
I really like your idea of the Marantz 7400 with Snells. That's the best combo of products mentioned IMO.
Username: Bnthouse
I went in a little bit different direction
I purchased the Snell xa60s with the marantz
7300 and then upgraded and added an anthem amp
(mca20)- the sound is great
Jake R
TJ: did you test the Marantz with B&Ws. What did you think?
