Home theater remote
Username: Spshond
Post Number: 34
What Universal remotes are out there that are great. MX500 universal, is it a good one. what recommendations
I got a Harmony 659 about a month ago. You connect it to the computer and it downloads all needed info to work your entire system.
All you need to do(your wife will love this)- is push one of four buttons: Watch TV, watch a video, Listen to Music or other.
You can(again from the internet) customize to any level you want.
No wierd remote to remote mating rituals or complicated button gymnastics.
Take a look at: Harmonyremote.com
Username: Gecko
Post Number: 14
Rico - how many components are you going to need to control?
That makes a big difference. Price range would also help as well.
