Ir in/out jacks on sony receiver
Username: Zoomru
Charleston, SC
What type of sensor is used for ir in or is this jack strictly input from another sony component...also i have used 2 emitters on the ir out jacks and get no response... are these strictly pass through for ir in or does it disable the front ir sensor on the amp....in either case when will I "See" signal transmission?
