Onkyo tx-sr601
grateful john
I just bought this receiver at CompUSA closeout priced at $259. I got the Polk RM6750 5.1 package for Christmas. Is this a good combination? I will be using it mostly for home theater with some music. Am I losing much by not adding the 6th speaker? Or what speaker should I look for as a 6th speaker?
Username: Shantao
Post Number: 80
john;
I have a 601 paired with polks and I am very happy with it. I don't think you will miss much by adding the back center. However, if your heart is set on adding it, then look into getting a polk center and using it as your front center, and then using the center that came with your 5.1 package and moving it to the rear center.
