Like
Picking a center speaker for Harman kardon 230 receiver
I am a newbie and I needed some advice I just bought a Harman Kardon avr-230 receiver to go along with my definitive 2006tl's I was wondering if anyone had suggestions for a center speaker that would match what I have for my fronts and my receiver. thanks for any advice in advance
Username: Riches1
Atlanta, GA US
Post Number: 59
I would try to find a Definitive center with the same driver size or least the same driver series as your 2006ti's if at all possible. That will give you your best sound match.
Otherwise you are going to have to deal with some compromise in the sound staging.
If that is not possible, then look for a center that would be as neutral as possible, maybe something like a Polk CSi3/CSi5, or an Infinity Alpha center if you prefer something a little brighter.
thanks for the suggestions I will check those out
Facebook
Shop Related Deals
Directory
