Help with some wiring questions please?!
hey. i would like to gather some information about wiring speakers up to my 97 ford taurus gl sedan, i pretty much blew the stock paper ones, so im looking at these 6x8 pioneer 3ways for 2 is 90 bux....pretty good i think, but anyhow i was curious if i could just cut my old stock speakers out and use that same wiring to hook my new ones up. and i do have a subwoofer as well,i dont know if that would make a difference in the wiring but...you never know with fords...i would greatly appreciate any information given. Thank you.
I think its ok but if your into super HQ than you should change them
if i may ask are you connecting them up to an amp or the head unit
Good Luck
Username: Audiobahnmahn
well i dont have an amp for them well i do but the amp would smoke the speakers...so im probably going to hook it up to the head unit. what do you mean by super hq?
Username: Cory
As in the future you would enter in sound quallity comp's in your area
