RXV3300vs THX certified RXV2400
Bobby Big Boots
Hey Hawk,
What is your opinion on the upper line Yamaha's matched with Paradigm Monitor 7's. Would the Rxv 3300 sound better than the THX - RXV2400. I also have to question the the difference in Weight in these two receivers. 48.5 lbs VS 35.lbs for the 2400. Is the 3300 a better receiver? Why such a weight diff??? Or should I look at Nad or even Dennon? HELP! I NEED SOME ADVICE!!!
Bobby Big Boots
Hawk!!
Are you out there?
