Hk avr430 shutting off HELP!
scott s
I got an hk avr430 a couple of weeks ago and it just started shutting off. I thought it was a safety feature for overheating but it does it in about five minutes now. I tried unhooking the cheap temporary speakers I had but no fix. Please help!
Username: Landlockedph
Dallas, TX
Post Number: 15
Try disconnecting all of your speakers and see if it runs. Use a pair of headphones. Maybe a stray wire from one of your speaker connections is causing it to shut down?
Good luck.
scott s
It does it even with the speakers unhooked and according to the many forums I've looked at it's not uncommon.
Username: Rd11
Post Number: 14
I hope you purchased from an authorized dealer...
