Which receiver is better??
Username: Takeshi
Pioneer VSX-D414-S or Sony STR-DE597
Which sound better?
Does pioneer VSX-D414 has Component input??
cause some site said "yes" and some said "no"...??
The sony seem to have better spec. It has 6.1 Channel and DTS ES...
But i hear a lot of protection problem on Sony STR-DE597, almost 9/10 people have that problem
is it ture??
Don't know much about the two you are looking at but I would check out this article on audioholics : http://www.audioholics.com/techtips/buyingguides/AVreceiversbuyingguide.php
One key comment "What Matters? Power Supply - Weight does!" In general a good amplifier will require the reciever to weigh more.
