SMALL ROOM. What kind of speakers??
WILSON94
Hi I am looking to upgrade my speakers for my home stereo that is located in my room, fairly small sized room at about 16 X 12 feet. I have been powering a large pair of 250 watt Audio Tech(no-name) speakers but I am fed up with the poor quality of sound. I have a NAD amp that pushes about 100w/c, and was hoping somebody had a suggestion of speakers, either a bookshelf pair or a floor model. I listen to hip hop/rap music, and LOVE BASS!
Thank you.
Username: Kano
Post Number: 213
I'd get some moderately priced speakers with a good powered subwoofer.
Since your room is small you may want to look at bookshelf speakers on stands.
and this subwoofer -
http://www.svsubwoofers.com/subs_pci_20-39.htm
Username: Project6
Post Number: 2187
What is your budget on speakers?
The SVS sub suggestion will feed your appetite for bass:-)
Username: Redwolf1978
Chtown, PE Canada
I would go for the Polk RTI4's paired up with a PSW10 sub.
Username: Kano
Post Number: 217
That PSW10 has a really high bottem bass extension and only 100W RMS.
I was going to add that stepping up to the SVS PC-Plus gives you another 200W RMS power.
http://www.svsubwoofers.com/subs_pcplus_20-39.htm
Check out PSBs line of speakers, JM Labs Chorus line, Quads .... kinda depends on your budget... these are reasonably priced great sounding speakers. -Rick
