Orb and athena
Username: Sam4age
After doing a bit research, I'm thinking of the following combination:
orb mod1 front (or should i stay with as-b1/b2?)
athena as-c1 center
athena as-b1 surround/rear
still need to decide on receiver and sub, if needed?
What receiver would you recommend from best buy?
Username: Sdc
Post Number: 26
What features are important to you and what are you looking to spend?
Username: Sam4age
I want to build a home theater system for movies. My wife got me $400 bestbuy gift card for xmas. I'm looking to spend a total around $600ish for now.
What are some suggestion? thanks
Username: Sam4age
How does the Rocket Tyke 5.1 compares?
SimpleLife
You'll really like the Orbs. You could get the Orb stereo system that has a sub and 2 satellites, and use the Athenas to fill that out into 5.1. That way, you get a really great sub, and aren't paying as much for the satellites if you purchased them separately and a sub separately. Alternatively, you could just go Athena all around, since Orb all around doesn't seem like an option b/c they aren't sold at BB.
Username: Sam4age
Post Number: 8
My other option is the Athena Mica vs Rocket Tyke. How does these 2 compares?
Username: Afrogt
Post Number: 19
The Athena Micro system is on sale for $249 in black right now at BB. You'll definitely save a lot of money. Don't know if they actually sound better than the Rocket Tykes though.
Username: Afrogt
Post Number: 20
Just in case you need the link
http://www.bestbuy.com/site/olspage.jsp?id=1077624907950&skuId=6376628&type=prod uct
