Need speakers for 5.1 system
stevie d
can anyone recomend speakers for my system
the receiver is a nad 753. I have the subwoofer
covered a velodyne vrp 1200b. also my budget is around $1000
Username: Earful
Post Number: 20
Are you looking for just two front speakers?
stevie d
no I need mains, A center, and surrounds
I know the budget is not too much but thats what i have for now
Username: Project6
Post Number: 2138
Look at the Ascend Acoustics cbm 170 all around...these would be perfect within your budget!
http://www.ascendacoustics.com/pages/products/speakers/cbm170/cbm170.html
Username: Maroonmike
Dixie, USA
Post Number: 37
I would also check out PSB speakers. The new Image series is excellent.
www.dmc-electronics.com
Username: Nuck
Parkhill, Ontario Canada
no doubt, you should check out psb. good advise from Maroon. I have never been disappointed in mine. They do seem to suck up a lot of power...
stevie d
thanks for the info on the psb's. Could you recomend a specifc center and mains. Also what do you think of the bi-polars for surrounds.
once again thanks for the recomendations
