Deciding which receiver for $500-800
PM
Ok, so I am looking to spend 500-800 on a new receiver. So far I have found the HK 430, Denon AVR 2805, Marantz sr5500, and the onkyo TX-NR801 or TX-SR702. I will primarily be using this for music, but with movies as well. Right now I am planning on buying wharfedale diamond 8 speakers for the set up and probably a velodyne cht 10 subwoofer. I was just wondering what anyone would reccomend. I do not care so much about the fancy features, more about the sound and quality. I think the room size is about 14x15.
thanks
Peter
