Which are better: Infinity Alpha 20 or Infinity Primus 150?
Username: Exerciseguy
Brooklyn, NY USA
Post Number: 54
Any input would help in deciding between these two entry level speakers? I know the Alpha series have been replaced by the Beta series, but let's leave them out.
Username: Trabadoor22
Deffinitly the Alphas. I used to have the Infinity alpha towers and they were very neutral and natural sounding. Much better than the Primus series speakers that I listened to the other day. The alpha's just had overall better clarity.
Brooklyn, NY USA
Post Number: 59
Thanks. Anybody else care to chime in?
edster922
Where does the Infinity Entra series fit in, is that between the Primus and the Alpha, or is the Alpha the replacement for the Entra?
Post Number: 9
I'm not exactly sure. I know the Alpha's were replaced by the Beta's. The Primus might be a replacement for the Entras, but that is just a guess.
Brooklyn, NY USA
Post Number: 60
I think edster922 is correct.
