Not getting any sound from pc
i have a soundblaster live 5.1 sound card in my system, brand new with a new motherboard. Just installed them and i get absolutely no sound. I go into my device manager and it says no sound device available. I installed the drivers, removed them and installed them again. the speakers are on and turned up. im really not sure where to go from there and i would like any help anyone could give me.
Username: Touche6784
Post Number: 40
try changing the pci slot that you are using. sometimes computers are stupid like that. you could also force install the drivers and by that i mean just add a device without having windows automatically search for it. this is what has worked from my experience. if you want more info try a computer forum as this is an audio forum. but im sure that someone else will be of more help than i.
