I bought the cambridge audio 640a azur (before 2 weeks ) and i want to return it to the shop and get the NAD C352?!
Username: Amir
Post Number: 28
in the Cambridge audio azur 640a i am hearing the sound quite well , but the middle vocals are not prominent and there isn't a good nature balance sound (when the Direct botton is in on) .
i cant swiching the trible button to low level.
and when i swich on the volume bottun just a little a hearing a huge sound ...
this amp doesnt suit to rock music...i think so.
my qustion is , if i will buy the nad c352 will i be notice to the differences?
i need an answer from someone who already heard the two amplifiers!?
and by the way, i bought this amp. cause i saw the excelent Specifications :
in azur 640a :
0.01% THD @ 20Hz - 20kHz
Frequency Response: 5Hz to 50kHz +/- 1dB
and in NAD C352 it's less impresive detailes:
Rated distortion (THD 20Hz-20kHz) 0.03%
Frequency response 20Hz-20kHz ±0.3dB
thank you.
amir
Username: Edison
Glendale, CA US
Post Number: 599
Might be your speaker or your cd player - more likely your speaker.
Which ones are you using?
