In Ceilings as surround
Username: Chuckh
Louisiana
A Paradigm dealer who sells Klipsch & Paradigm told me that he recommends Klipsch in-ceiling speakers as surround even though I would be using Paradigm Performance or Monitor fronts and center. States there's not as much difference between different companie's in-ceilings as there are in floor or bookshelf speakers. So would this combo be Ok as opposed to using Paradigm in ceilings. Also, has anyone compared Paradigm Stylus 150 outdoor to the Klipsch AW-500s.
Username: Shantao
Post Number: 64
While I personally like the klipsch sound, I am not so sure how those horn loaded klipsch in ceilings would sound with paradigms.
I would think that it would be a better match to stay with the paradigm in-ceilings since there would be a better tonal match.
Username: Frank_abela
Berkshire UK
Post Number: 218
I would go with Paradigm's own speakers or, failing that, go with Speakercraft which have adjustable crossovers allowing you to set them up appropriately for the environment.
Regards,
Frank.
Hey Chuck, Check out the in ceiling line from Sonance. A California company that builds in ceiling speakers for their main business. They have designed an in ceiling speaker called the LCR1.0 and also the LCR2.0. These are specifically designed for ceiling theaters. Check them out here. www.sonance.com
