Motor upgrade for rega planer 3
Username: Flaxton
Post Number: 11
Any advantage in upgrading my motor on my rega planar 3 turntable. I HAVE HAD IT REWIRED and had an upgraded counterweight put on it. Thanks.
Username: John_a
Post Number: 2563
I was wondering about that, too. On another thread here Frank Abela wrote (October 5) "The motor upgrade improves the deck's pitch stability quite a bit. It's also meant to improve noise, although I haven't observed this myself to be honest (whereas I have noticed the pitch stability improvements). The motor upgrade is no joke - it really improves the deck substantially"
Username: Frank_abela
Berkshire UK
Post Number: 221
Honest, it does! :-) They're using a different quieter motor which allows them to mount it directly to the plinth.
Regards,
Frank.
Username: John_a
Post Number: 2572
Thanks, Frank. I quoted you not because I doubt you, but because it is the only feedback we have had on this question, and I have no first-hand experience. One cannot audition a motor upgrade! My P3 with original motor and tonearm still beats CD any day. Your opinion counts, and I will consider this recommendation very seriously early next year.
