Volume malfunction - HK 7300
Troubled
I just got the HK AVR 7300. After a few days use, the volume control on the remote controls started to malfunction, so it seems anyway. When I hit either arrow to increase or decrease volume, the receiver doesn't increase or decrease volume by one notch, but instead increases or decreases ALL THE WAY until the volume level is at +80 (i think - haven't actually seen it go that high) or -80. Has anyone had this problem before? Did I accidentally screw with some setting?
The malfunction began after I unplugged the front speakers on the receiver once to isolate the rear speakers to hear how they sounded. I can't imagine this caused it?
Thanks
