Denon "reset"
Username: Garrett
CHICAGO, ILLINOIS
anyone know how to totally reset and denon receiver
is that even possible?
Username: Elitefan1
Post Number: 843
On my old Denon 2802 there was a section called "resetting the microprocessors" or something very similar. Look for that in the index. I assume it won't come on? Mine got a surge and went out but this reset brought it back to working order.
What receiver do you have?
Username: Pedro
Hi,
the Denon AVR-1905 is reset by holding down the Speaker A & Speaker B buttons while powering it on. It differs from model to model, so check your manual, there should be a section there telling you what to do. If you don't have your manual, you might be able to download it from Denon USA website.
Cheers,
Pedro
