Blue Light Audio
Username: Nutopia
Post Number: 18
Can someone tell me a little about this. I hear it's supposed to replace SACD. What are the improvements? Do they really plan on putting out new discs to fit this format? Any/all info would be appreciated!
Username: Tevo
Chicago, IL USA
Post Number: 54
I believe you are referring to Blu Ray.
http://www.blu-ray.com/info/
http://www.audioholics.com/techtips/specsformats/JVCBluRayDVDComboDisc.php
Username: Nutopia
Post Number: 19
You're right. I was thinking the person who posted the message I read was off. Is this technology going to get into Audio as well? Most of the stuff I read there mentioned HD Video.
Username: Tevo
Chicago, IL USA
Post Number: 55
Not sure. From what I understand, the main advantage is the significantly higher capacity and flexibility of this format.
With regards to audio, It is not clear to me whether there are or will be any advantages in terms of sonic quality above and beyond SACD / DVD-A.
The next generation PlayStation gaming console is supposed to use this new format.
