Sony 3ohm 5.1 home theatre speakers
Can you help I have purchased a sony strdb780 receiver and want to run the above speakers (rear,front,centre only but speaker impedance is 3ohm. The receiver info states you can switch between 4ohm setting or 8ohm setting. At the moment I have a powered sub attached....Have I stuffed up....Thank you.(Australia calling)
