NADC352 vs c370
Username: Tzeleung
Post Number: 8
I just found out 2 NAD amp deal in the same price: Both C352 and C370 are selling $450
My question is which Amp have a better msuical sound?
I don't care much about the power since I just got a small apartment.
thanks
Username: Nm2285
Delaware
Post Number: 47
Go with the C370. The extra power translates into better dynamics, not just more volume. It can never hurt.
OnimushaLord
I would go with the C352, Best Buy in HFC and Amp of the Year 2003/04 in What Hi Fi. You should consider the 370 though if your speakers are terribly hard to drive, otherwise 80w/ch is good enough to cause hearing impairment in a small room. Cheers!
nout
Listen both I'd suggest. Which one's better? Tough question, perhaps a slight preference towards the NAD 370.
iain
The C370 is an incredible amplifier. The 352 is wonderful as well but again the extra power give better dynamics. They are otherwise much the same but the 370 usually costs more.
