Need help!! ===> im clearly an idiot---denon 3802 setup
i just bot and installed a denon 3802. i cant get past the initial system setup....when i hit the correct button, im expecting to see the system menu on THE DENON UNIT...am i not right? when they say 'onscreen display', do they mean the tv? if so, which connection should i make between the unit and the tv so i can get this bad boy up and running? thanks a million
Add a cable (S-Video or composite) to the TV's input. You should see the on-screen display on the TV.
