Pansat2500A
Username: Lynchnet
We have a pansat2500A set up. The problem is we can't get 119 and 110, even though the quality is 91. It keeps coming up on the screen scrambled or bad channel. Can anyone help?
Thanks
lynchnet
new guy
PLEASE HELP... when i turn the power on...my pansat 2500a blinks the three lights then it says "on", then turns right off... after 30 seconds or so, it'll do the same thing... I'm not sure what to do... I can't even get back to the factory settings to reset it b/c it won't stay on long enough... i even unplugged it and powered it off for a day and it's still doing the same thing...
