Is there away to shield - unshielded speakers.
Username: Xgrizzlyx
Post Number: 59
I have unshield dual 10" cadence subwoofers in a sealed boxed.
It was custom made at a local car audiio place that also was doing home audio. This was back 8 years ago. These woofers are great but just not shielded. Is there away to seal them. My current tv is 36" and it was easy enough to be a good distance away from the tv not to be a problem. but plan on getting a 52 or 61 JVC lcos tv.
Username: Project6
Post Number: 1973
try using a bucking magnet
check this
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=329-210
Username: Xgrizzlyx
Post Number: 62
Thanks that should do it!!!
And as no more then a buck or so I guess it wouldn't hurt to try :D
