Cd a/b switching
sandy
say i wanted to have 2 seperate cd players hooked up to the one amp which only has one cd input, is there any way of purchasing an a/b switch that would allow me to do this without having to continually change the connections to switch between players?
thanks
S
nout
You don't have to use the CD input necessarily to connect a cd player.
You can also use the AUX and TAPE inputs.
So in your case: CD for cd player1 and AUX or TAPE for cd player 2
But never use the PHONO and TUNER inputs for your cd players
sandy
oh right - thanks
i understood never to use the phono or tuner inputs so i just presumed it was the same scenario for tape and aux :0)
nout
With most amps these inputs (CD TAPE AUX) are identical.
For a cd player these inputs are actually too sensitve: when turning the volume knob on your amp at 9 o'clock it will sound already extremely loud.
A few brands like Quad en Meridian give you the option to adjust these input values to your own likings.
sandy
on my amp the phono/aux input is one and the same, take it i avoid this one and opt for either the av/dvd ot md/tape2 inputs with the second player then?
nout
Yes, I would do that, although it wouldn't hurt if you connected your player to phono/aux I guess.
I'd go for md/tape2 of which I'm certain it is identical to the cd input.
