Choices based on availability
Hi
My brother gave a NAD T743 as an advance Christmas gift. Currently im hooking it to my old DM302 and I think theres a hint of a little harshness and it lacks detail and punch. I would like to upgrade to higher bookshelfs but my brother said there are only four brands available in his place: Paradigm, B&w, Monitor Audio and PSB. For $400(its the only amount he set aside for speakers) or less, please give me your recommendations from these four brands.
Thanks.
Username: Elitefan1
Post Number: 811
Check out the Paradigm Mini-Monitor and the MA Bronze B2. Both are excellent but do have different sonic characteristics. Whichever you like better will serve you well. I would probably choose the Paradigm myself.
Thanks elitefan.
But if the budget is increased to $600, would you recommend other models among the four brands?
Thanks.
Username: Nm2285
Delaware
Post Number: 49
Those are all great manufacturers. The best would be to listen to them all on the amp you're using. Decide for yourself. None of them should let you down.
Username: Elitefan1
Post Number: 826
For $600 you can move up to the Paradigm Monitor 5 or the MA Silver 2 if you get it mail order. I doubt if any dealer will sell it at that price.
