Need a decent, cheap, CHEAP sub... is Velodyne the only option?
Username: Destro713
Chicago, IL U.S.A.
Post Number: 13
I'm looking to get a decent sub and I want to spend as little as possible. $200 shipped is basically my absolute maximum, and I'd like to go lower if possible.
So far the only ones I know of that fit the bill are the Velodyne VRP-1000 and CHT-8. Are there any others I should try researching?
hksub
hksub from harmanaudio.com
